Identify connector?
Diskutiere Identify connector? im Nissan NV200 Forum im Bereich ---> Die Fahrzeuge; Do yo know the purpose of this connector behind the rear speaker? I think it is power cable, but what for?
  1. #1 JiMsHaDy69, 12.11.2019
    JiMsHaDy69
    JiMsHaDy69 Neues Mitglied
  2. #2 Maddiehn, 12.11.2019
    Maddiehn
    Maddiehn Neues Mitglied
    Does your car have tire pressure monitoring? If not this could be the connector for the sensor in the back.
  3. Muc
    Muc Mitglied
    If this only on the right side then it must be the connector for the optional cooling fan in the back.
  4. #4 JiMsHaDy69, 12.11.2019
    JiMsHaDy69
    [QUOTE = "Maddiehn, post: 159809, member: 10880"] Does your car have tire pressure monitoring? If this could not be the connector for the sensor in the back. [/ QUOTE]
    It does have TPMS but it's fully connected as far as I'm aware. No errors.
  5. #5 JiMsHaDy69, 12.11.2019
    JiMsHaDy69
    [QUOTE = "Muc, post: 159810, member: 10619"] If this is just the right side then it must be the fan for the optional fan in the back. [/ QUOTE]
    I did not know there is an option for a fan. I need to Google for information.
  6. #6 Maddiehn, 12.11.2019
    Maddiehn
    Do you have a smart key system?
      Dateigröße:
      20,3 KB
      Aufrufe:
  7. #7 JiMsHaDy69, 12.11.2019
    JiMsHaDy69
    No smart key system. I think I need to check the connector using a voltmeter to know if there is power.
  8. #8 Maddiehn, 12.11.2019
    Maddiehn
    Is the connector only on one side of the car, or is it on both sides available?
  9. #9 JiMsHaDy69, 13.11.2019
    JiMsHaDy69
    The connector is on the one side only.
  10. #10 JiMsHaDy69, 24.11.2019
    JiMsHaDy69
    I have not checked the wire yet with a voltmeter, but I did not make the time to replace the factory speakers with some kicker speakers.
Identify connector?
    Information ausblenden
